1st post here. After using the orange pad and SHR and the white pad with FMP, I then did the MSW with the gray pad. Waited about 30 minutes and wiped the car down. Car looks great, Adams products worked very well!!
But.....after the 12 hour curing period, the surface did not change and I did not not wipe any residue off because there was none. Did I not use the MSW correctly? Maybe I initially wiped it off too quickly? Should there be something to wipe off??? It was about 75 degrees in the shade when I applied MSW.
CFMINI
1st post here. After using the orange pad and SHR and the white pad with FMP, I then did the MSW with the gray pad. Waited about 30 minutes and wiped the car down. Car looks great, Adams products worked very well!!![:2thumbs:](//content.invisioncic.com/l231836/emoticons/default_2thumbs23.gif)
5 answers to this question
