SYMAWD Posted September 12, 2016 Share Posted September 12, 2016 So this should be interesting. Since there is silica in it, I figure it should be able to hold up to some heat and have some coating characteristics (brake dust should theoretically rinse off more easily). Let's find out as I update this thread in the future. Here is the initial cleaning anyway. Link to comment Share on other sites More sharing options...
wely324 Posted September 13, 2016 Share Posted September 13, 2016 (edited) I actually did the same thing today, after washing the wheels with DWC, and after I washed the car I then used Wash and wax on the face of the wheels with a clean brush. This might be a nice way to replace LPS, although it probably won't last nearly as long, it will be a lot easier to apply protection. Edited September 13, 2016 by wely324 Link to comment Share on other sites More sharing options...
avimore Posted September 13, 2016 Share Posted September 13, 2016 ^Great idea. I wash my wheels weekly with water and CWS, so using W&W instead of CWS on the wheels should be a good way to keep up the protection. Link to comment Share on other sites More sharing options...
LT1xL82 Posted September 13, 2016 Share Posted September 13, 2016 The idea of using W&W on wheels is certainly appealing...especially complex wheels! Hopefully it can be done with precious little getting on the rotors and brake pads...I'm not a fan of wax/polishes/wheel cleaners/etc getting on a brake system's working surface. Link to comment Share on other sites More sharing options...
Gen9Rolla Posted September 13, 2016 Share Posted September 13, 2016 Interesting idea, can't wait to see the results! Link to comment Share on other sites More sharing options...
Ricky Bobby Posted September 15, 2016 Share Posted September 15, 2016 Matt subscribed to your testing. A soap on well maintained wheels that adds protection is surely advantageous Link to comment Share on other sites More sharing options...
SYMAWD Posted September 22, 2016 Author Share Posted September 22, 2016 Here it is 10 days later. At least with a normal hose, the brake dust is no easier to rinse off, but once agitated, it does remove easily. It definitely adds protection as you can see the brake dust beaded up with the water once agitated. Seems like it would be worth using on your wheels every so often as it definitely adds protection. Before: After just rinsing: Agitated: Link to comment Share on other sites More sharing options...
Gen9Rolla Posted September 23, 2016 Share Posted September 23, 2016 Thanks for following up with this, will have to try it out myself soon Link to comment Share on other sites More sharing options...
avimore Posted September 24, 2016 Share Posted September 24, 2016 Here it is 10 days later. At least with a normal hose, the brake dust is no easier to rinse off, but once agitated, it does remove easily. It definitely adds protection as you can see the brake dust beaded up with the water once agitated. Seems like it would be worth using on your wheels every so often as it definitely adds protection. Thanks for the follow-up. Would you say that you noticed less brake dust collect on the wheels? Or was it the same amount of brake dust, just easier to remove once agitated? Link to comment Share on other sites More sharing options...
SYMAWD Posted September 24, 2016 Author Share Posted September 24, 2016 Thanks for the follow-up. Would you say that you noticed less brake dust collect on the wheels? Or was it the same amount of brake dust, just easier to remove once agitated? Maybe slightly less, but it's hard to say because there is no way to see how much the brakes were applied between cleanings (could have been more the previous week, than this week). Link to comment Share on other sites More sharing options...
