stripesace Posted October 1, 2015 Share Posted October 1, 2015 Is everyone using waterless towels when using diluted rinseless as a waterless? Link to comment Share on other sites More sharing options...
0 NG13 Posted October 1, 2015 Share Posted October 1, 2015 I believe that is the recommendation. I use the waterless towel to remove the dust with the roll as you wipe method. Then I follow up with a plush towel to buff it out. LT1xL82 1 Link to comment Share on other sites More sharing options...
0 Chris@Adams Posted October 1, 2015 Share Posted October 1, 2015 Yes, I use the WW towel with RW. Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted October 1, 2015 Share Posted October 1, 2015 I believe that is the recommendation. I use the waterless towel to remove the dust with the roll as you wipe method. Then I follow up with a plush towel to buff it out. I do "roll as you wipe" and use an unused portion of the waterless towel to remove streaks. Once the car is done, I do a fast Detail Spray with a double soft to catch any (hopefully very minor) missed areas and streaks. I fold the double soft twice, wipe area with Detail Spray, flip towel and do a final buff. Occasionally, the vehicle is wet from rinsing off grime deemed to much for waterless washing only. In that case, I have tried a Great White Drying Towel instead of the waterless towel. Being somewhat concerned the added water on the car may dilute the 16:1 rinseless as waterless too much, I'm thinking I may try a more concentrated dilution. But then again, rinseless used as rinseless wash is not very concentrated. Thoughts? Link to comment Share on other sites More sharing options...
0 wely324 Posted October 1, 2015 Share Posted October 1, 2015 I do "roll as you wipe" and use an unused portion of the waterless towel to remove streaks. Once the car is done, I do a fast Detail Spray with a double soft to catch any (hopefully very minor) missed areas and streaks. I fold the double soft twice, wipe area with Detail Spray, flip towel and do a final buff. Occasionally, the vehicle is wet from rinsing off grime deemed to much for waterless washing only. In that case, I have tried a Great White Drying Towel instead of the waterless towel. Being somewhat concerned the added water on the car may dilute the 16:1 rinseless as waterless too much, I'm thinking I may try a more concentrated dilution. But then again, rinseless used as rinseless wash is not very concentrated. Thoughts? If you are rinsing the vehicle off why not do a full rinseless wash as the car will be less prone to scratching than the waterless wash... and a GWT and waterless towel are the same other than overall size, so it may help with soaking up the water but is no more or less scratch resistant than a blue waterless. LT1xL82 1 Link to comment Share on other sites More sharing options...
0 LT1xL82 Posted October 2, 2015 Share Posted October 2, 2015 If you are rinsing the vehicle off why not do a full rinseless wash as the car will be less prone to scratching than the waterless wash... and a GWT and waterless towel are the same other than overall size, so it may help with soaking up the water but is no more or less scratch resistant than a blue waterless. I think I will try your suggestion. I have a moderately good supply of single soft towels so maybe a "Gary Dean" rinseless wash would work well when the car is wet from being pre-rinsed. Link to comment Share on other sites More sharing options...
stripesace
5 answers to this question
