So I tested out the Cyclo today, did half of my hood. I put an 'X' of Finish Polish on the white foam pads, and them gave each pad a spray of DS.
Spread the product out over half the hood, then started on level 4-5.
However, the product seemed to dry out / flash very quickly. I even added a couple drops more on each pad about half way through. I wasn't in the direct sun. I did this around 7 when then sun was down behind trees. I also first wiped down the hood with Rinseless and then clayed with Rinseless spray mix.
Comsidering my space gray color, I was also not really easy to see the product on the hood, so maybe I just THOUGHT it dried/flashed quicker than expected.
Also, when removing the polish with a double soft, it was not slick at all! Is that normal?
Finally, when finished, I couldn't see any difference between the side of the hood I did vs the side I didn't touch.
I guess this is when a detail clinic would help me.
PT3
15 answers to this question
