hockeybawler Posted March 10, 2015 Share Posted March 10, 2015 Was thinking today and can this brush also be used to clean rubber floor mats? I know there is the cockpit brush that would be better suited for this probably but didnt know if there is any harm in using the wheel brush. Thanks for the help! Link to comment Share on other sites More sharing options...
0 Ricky Bobby Posted March 10, 2015 Share Posted March 10, 2015 Shouldn't be an issue at all. I usually use the Fender Brush. I wouldn't clean floor mats and wheels though with the same brush. Never know what kind of pieces of grit/asphalt might get stuck in it. Thats why I use the Fender brush bc I'm only cleaning tires/wheel wells with it. TheBurninator and Junior 2 Link to comment Share on other sites More sharing options...
0 TheBurninator Posted March 10, 2015 Share Posted March 10, 2015 I've used both before. The fender brush seems to better clean rubber mats. The bristles aren't stiff enough on the tire brush IMO. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted March 10, 2015 Share Posted March 10, 2015 The wheel brush would be wasted on that kind of work... you need something with more scrubbing power, plus you don't want to use a brush that will be in contact with your wheels picking up sand and other nastiness from your floor matts then scratching your wheels. I use the tire scrub brush or the fender brush on mine. Link to comment Share on other sites More sharing options...
hockeybawler
3 answers to this question
