McMo Posted June 24, 2013 Share Posted June 24, 2013 I have the older version 7424 still kicking around (not the newer XP). It is still in perfect working condition. My questions are, are all the products and accessories - polish, pads, backing plate - compatible with the older version? Is the technique essentially the same? I assume it will be slower going. I may eventually upgrade to something newer, but I would like to try this out first. Link to comment Share on other sites More sharing options...
0 GerryC Posted June 24, 2013 Share Posted June 24, 2013 Yes. I also have the non-xp version. It is basically the same machine, except the XP model can go up to 6800 opm (vs 6000) and has a longer cord. McMo 1 Link to comment Share on other sites More sharing options...
0 goheels Posted June 24, 2013 Share Posted June 24, 2013 I have the XP version and I rarely crank it up all the way for polishing, as it causes too much vibration on my hands and I can work pretty effectively at slower speeds. IMHO, stick to the original or upgrade to a different (non-PC) machine. McMo 1 Link to comment Share on other sites More sharing options...
0 Team Adam's Posted June 24, 2013 Share Posted June 24, 2013 Yep... nearly an identical tool to the XP... it was more an evolutionary change than anything. They moved the speed dial, rounded out the body a little and gave it about 800opm more at top speed. Your older 7424 will work just fine. McMo 1 Link to comment Share on other sites More sharing options...
0 McMo Posted June 25, 2013 Author Share Posted June 25, 2013 Thank you for the responses, everyone. I was hoping I could use this machine. Can't justify pulling the trigger on something else until I give this a go. Link to comment Share on other sites More sharing options...
McMo
4 answers to this question
