WayneZito Posted June 15, 2013 Share Posted June 15, 2013 When hand polishing swirls and scratches around door handles how much pressure do you use ? Link to comment Share on other sites More sharing options...
0 egott_91 Posted June 15, 2013 Share Posted June 15, 2013 A lot! Lol. Honestly, I never hand polish, Except for revive. Link to comment Share on other sites More sharing options...
0 GerryC Posted June 15, 2013 Share Posted June 15, 2013 As much as you want/need to get the results your looking for.. There isn't a set amount to use, especially since your clear coat and the severity of your scratches is different than everyone else's. The only time you need to apply a proper amount of pressure is when using a machine because it can affect the rotation and movement of the pad. Link to comment Share on other sites More sharing options...
0 MrHot88 Posted June 16, 2013 Share Posted June 16, 2013 If you were using a strong compound I'd say be careful but with Adam's it's safe to do by hand without the risk of going through your clear. I'll say this, in most cases you don't have to rub hard, let the correcting polish do the work for you. Kevin Link to comment Share on other sites More sharing options...
WayneZito
3 answers to this question
