13-Mustang-GT/CS Posted May 28, 2013 Share Posted May 28, 2013 I just applied face melt to my car as well as sealed my glass. Is there a certain type of windshield washer fluid I have to use to make it last longer? Also what brand of fluid do you guys use with best results for sealed glass? Link to comment Share on other sites More sharing options...
0 ForceofWill Posted May 28, 2013 Share Posted May 28, 2013 I try not to use my washer fluid ever. I keep an emergency detail kit in my car with: MF towels, Detail Spray, Glass Cleaner, WW and APC BKazzle 1 Link to comment Share on other sites More sharing options...
0 Chewy Posted May 28, 2013 Share Posted May 28, 2013 I don't use the generic blue stuff or the Rain-X branded stuff. I DO use the stuff that's more stable at lower temps, but like Tom, i seldom use it. When you need it, you NEED it. Most of them will have alcohol in them so they'll all degrade the sealant over time. Just using the wipers degrades the sealant, so every month or so, hit it again. If you're in an area that doesn't freeze, you can use straight water, or if you're super wealthy you can fill it with Adams Glass Cleaner. Personally, I'd just reapply every so often. Chris Link to comment Share on other sites More sharing options...
0 BKazzle Posted May 28, 2013 Share Posted May 28, 2013 I do what Tom does. I'm a freak for clean glass, so most of the time I'm not caught without at least glass cleaner and a towel. Link to comment Share on other sites More sharing options...
0 BKazzle Posted May 28, 2013 Share Posted May 28, 2013 I don't use the generic blue stuff or the Rain-X branded stuff. I DO use the stuff that's more stable at lower temps, but like Tom, i seldom use it. When you need it, you NEED it. Most of them will have alcohol in them so they'll all degrade the sealant over time. Just using the wipers degrades the sealant, so every month or so, hit it again. If you're in an area that doesn't freeze, you can use straight water, or if you're super wealthy you can fill it with Adams Glass Cleaner. Personally, I'd just reapply every so often. Chris It will withstand the heat and not breakdown? Link to comment Share on other sites More sharing options...
0 13-Mustang-GT/CS Posted May 28, 2013 Author Share Posted May 28, 2013 Yeah I have a detail kit with everything in it. I use glass cleaner and glass microfiber almost everytime I'm about to leave. But there are sometimes where you need it and have to use it. I was gunna put the glass cleaner right into my car and use that as my fluid. But I'm not sure if that is safe Link to comment Share on other sites More sharing options...
0 GerryC Posted May 28, 2013 Share Posted May 28, 2013 If you're in an area that doesn't freeze, you can use straight water, or if you're super wealthy you can fill it with Adams Glass Cleaner. Personally, I'd just reapply every so often. Chris Maybe a solution of one part GC and two or three parts H2O ? Anyway you'll definitely have to reapply Glass Sealant to the windshield more often than the rest of the car. I do all my glass in March/April and then again in October. The windshield gets at least one other coating in the middle of summer. Link to comment Share on other sites More sharing options...
0 SYMAWD Posted May 28, 2013 Share Posted May 28, 2013 Quick sealant on glass works well too. It starts moving up the glass at 35MPH. A month later, it starts working at 45 for me,but everyone else in my family uses the wipers so it has been degraded some. Link to comment Share on other sites More sharing options...
0 J.greenroyd Posted May 28, 2013 Share Posted May 28, 2013 Glass cleaner for windshield wiper fluid....genius!! I'm going to try it Link to comment Share on other sites More sharing options...
0 13-Mustang-GT/CS Posted May 28, 2013 Author Share Posted May 28, 2013 Glass cleaner for windshield wiper fluid....genius!! I'm going to try it Trade 2 gallon of detail spray for 2 gallons of glass cleaner lol Link to comment Share on other sites More sharing options...
0 J.greenroyd Posted May 28, 2013 Share Posted May 28, 2013 haha i have plenty of glass cleaner so im good Link to comment Share on other sites More sharing options...
0 Team Adam's Posted May 28, 2013 Share Posted May 28, 2013 be cautious not using approved wiper fluids. they typically contain a certain amount of alcohol to keep the system clear as well as prevent freezing in winter. if you want your sealant to last, try to avoid using wiper fluid at all. the alcohol will degrade the sealant as will the mechanical action of the wipers. Link to comment Share on other sites More sharing options...
0 MrHot88 Posted May 28, 2013 Share Posted May 28, 2013 Could you cut it 50-50? Adams Glass cleaner and water? I don't use the generic blue stuff or the Rain-X branded stuff. I DO use the stuff that's more stable at lower temps, but like Tom, i seldom use it. When you need it, you NEED it. Most of them will have alcohol in them so they'll all degrade the sealant over time. Just using the wipers degrades the sealant, so every month or so, hit it again. If you're in an area that doesn't freeze, you can use straight water, or if you're super wealthy you can fill it with Adams Glass Cleaner. Personally, I'd just reapply every so often. Chris Link to comment Share on other sites More sharing options...
13-Mustang-GT/CS
12 answers to this question
