I'm fairly new to Adams - only 2 purchases under my belt, one of which was all the exterior and interior cleaning basics, and the second being a couple gallon refills once I knew for sure how great Adams was. I have been wanting to get into polishing but don't really know where to start and what to get.
I've never used a polisher before, so I am under the impression I should get the Porter Cable because I'm new, but all I have been hearing about is how good the Flex is. Putting the price of the machines aside, which would be better for me? Would the flex be problematic for me because I've never used a polisher before?
I've watched all the Adam's videos for polishing but still don't fully understand how to go about it. The first two cars I will be polishing are a Silver 2006 Acura RL and a 2010 Mercedes E350. I know the Mercedes will probably only need the Swirl and Haze Remover/Fine Machine Polish Steps, but I'm thinking the Acura will also need the Severe Swirl Remover.
One of my questions is do I only work one panel at a time? Do I go through each polishing step on a single panel and then move to a new panel? Or do I use one polishing step on the whole car - then proceed to the next step on the rest of the car. This is probably a dumb question but I have no experience.
After the polishing I know I need to protect it. I was planning on using Brilliant Glaze to add some shine and then the Americana for protection. I've been seeing people talking about Machine Super Sealant also. Is it necessary for me to use a sealant in addition to Americana? And if so, that is applied directly after the polishing and IPA wipe down? Also if someone could explain how to do an IPA wipe down that would be great.
Oh I forgot about claying too, but that seems pretty simple and straight forward - Approximately how long does the Clay Bar from Adams last? Assuming the cars that I'll be using it on aren't too contaminated.
That's everything I can think of at the moment, any help you guys can provide would be great! I appreciate it.
Performance Auto Detailing
First off sorry for the lengthy post,
20 answers to this question
