travis64 Posted January 12, 2013 Share Posted January 12, 2013 shampoo clay shampoo again haze remover by hand revive by hand glaze quick sealant americana does this look good?about to do my 1st wash with all this thanks! Link to comment Share on other sites More sharing options...
0 txredgt Posted January 12, 2013 Share Posted January 12, 2013 If you're going to do sealant, glaze, and wax then it needs to be in the order I just stated. Sealant needs to bond directly to your paint, just remember that and it all makes sense. So remember to use an applicator to spread the sealant and not just spray it on the car. Lastly for mayben it's required to post pictures! Link to comment Share on other sites More sharing options...
0 egott_91 Posted January 12, 2013 Share Posted January 12, 2013 Haze remover by hand isn't going to really do much of anything other than waste product UNLESS you have super fine swirls then those MIGHT come out with some elbow greae. Also, like stated above, sealant goes on bare paint before anything else. Then add the "wow factor" products, aka glaze and wax. Link to comment Share on other sites More sharing options...
0 egott_91 Posted January 12, 2013 Share Posted January 12, 2013 (edited) Double post gremlin... Edited January 12, 2013 by egott_91 Posted twice when I hit reply. Link to comment Share on other sites More sharing options...
0 FarbeyondDriven Posted January 12, 2013 Share Posted January 12, 2013 Haze remover by hand isn't going to really do much of anything other than waste product UNLESS you have super fine swirls then those MIGHT come out with some elbow greae. Also, like stated above, sealant goes on bare paint before anything else. Then add the "wow factor" products, aka glaze and wax. i beg to differ. I've used severe swirls remover and swirl and haze remover by hand and it actually does get out a good amount of swirl marks. Its obviously not going to do what the PC or flex would do. But youll definitly see an improvement!! Link to comment Share on other sites More sharing options...
0 THE Mook Posted January 12, 2013 Share Posted January 12, 2013 shampooclay shampoo again haze remover by hand revive by hand glaze quick sealant americana does this look good?about to do my 1st wash with all this thanks! Hi there! There isn't really a need to wash the car again after clay. Usually I leave the residue on and go right into polish. If you end up using an entire clay bar on one car, then wash it again. SHR will make the paint look better but don't expect the same results that you would have via using it with machine. Revive, then QS, then BG, then APW. Mook Link to comment Share on other sites More sharing options...
0 Rich Posted January 12, 2013 Share Posted January 12, 2013 You need one of these: Link to comment Share on other sites More sharing options...
travis64
shampoo
clay
shampoo again
revive by hand
glaze
quick sealant
americana
thanks!
6 answers to this question
