LornesAV Posted August 16, 2012 Share Posted August 16, 2012 How do I remove the 6" pad to install the 4":( Link to comment Share on other sites More sharing options...
0 dsmith2013 Posted August 16, 2012 Share Posted August 16, 2012 How do I remove the 6" pad to install the 4":( I'm assuming you mean on the PC? In which case you put the wrench that came with the PC on the nut behind the backing plate to keep it from turning, and then unscrew the backing plate. Link to comment Share on other sites More sharing options...
0 LornesAV Posted August 16, 2012 Author Share Posted August 16, 2012 Yes and I should have figured that out. My only problem now is what did I do with that damn wrench. Link to comment Share on other sites More sharing options...
0 dsmith2013 Posted August 16, 2012 Share Posted August 16, 2012 You should be able to fit a regular 9/16" wrench behind the backing plate. Link to comment Share on other sites More sharing options...
0 LornesAV Posted August 16, 2012 Author Share Posted August 16, 2012 Thanks Link to comment Share on other sites More sharing options...
0 LornesAV Posted November 12, 2012 Author Share Posted November 12, 2012 Regular opened end wrenches are to thick. Check a few local places figuring a router wrench or something similar would work, so far out of luck. Link to comment Share on other sites More sharing options...
0 Team Adam's Posted November 12, 2012 Share Posted November 12, 2012 LornesAV is correct... a standard wrench will be a tad too fat to fit in there, but flat specialty wrenches can be found at most hardware stores. Just have to look for them. I've also used a long skinny set of needle nose pliers to get in there and hold it. Not ideal, but when you don't have the wrench on site it works in a pinch. Link to comment Share on other sites More sharing options...
LornesAV
6 answers to this question
