Badge glue removal
Mels SS
A friend of mine has a late model Impala he removed all the badges on the vehicle. The impala badges on both side left the glue behind he said its very
hard substance any idea on removal of the glue??? :help:
14 answers to this question
3M eraser wheel. You should be able to find one at your local auto parts store. It's so much quicker than adhesive remover.
Here ya go
[ame=http://www.amazon.com/3M-Stripe-Wheel-07498-Hardware/dp/B00063VT0G]Amazon.com: 3M Stripe Off Wheel 07498, 4 in x 5/8 in, w/Hardware - 7498AM: Home Improvement[/ame]
Jeff, I always use a hair dryer, I would be afraid to use a heat gun.
^^ This. I use both as I have a variable heat adjustment but 99% of the time I just use an old one of my moms hair dryers she didnt want anymore. A good idea is you can just go to like a salvation army and pick up an older hair dryer for like 2 bucks and your set and ready to go. Stealing the wives and her finding it in the garage is not going to end well haha.
try these links..
http://www.adamsforums.com/forums/general-detailing-discussion-questions/16570.htm
http://www.adamsforums.com/forums/general-detailing-discussion-questions/16370-3.htm
I used fishing line to remove the badges. It left the tape and adhesive. Heated it with hair dryer, plastic razor to scrape it off. Went to walmart, got turtle wax spray adhesive remover. sprayed it on let it set a few minutes,, wipe off with alittle scrubbing and some Adams All Purpose Cleaner. Then cleaned everything up and gave her a good detail again.
If you got the badges off,, just the spay adhesive will work great to remove the left over residue. Pinstripes the same,,, hairdryer,, plastic scraper and spray adhesive remover.
:cheers::cheers: :patriot:
