babaron Posted January 12, 2012 Share Posted January 12, 2012 In my foolish haste, I inadvertantly put buttery wax over the machine super sealant without allowing it to cure. What should I do to correct this? Reclay and start over or what? Link to comment Share on other sites More sharing options...
chas Posted January 12, 2012 Share Posted January 12, 2012 How long did you let MSS cure for? There should be no need for a reclay since you don't need to pull up contaminants from the paint again, worst case scenario just strip the wax with either IPA wipedown, wash with a bit of APC mixed into your shampoo, or a dawn wash and it should take both layers off and give you a platform for re-applying. (Edited, removed comment, don't want to give OP incorrect info) Link to comment Share on other sites More sharing options...
paoutdoorsman Posted January 12, 2012 Share Posted January 12, 2012 You may even be able to get away with just reapplying MSS again over what you currently have in the paint, letting it cure properly and then reapplying more Buttery, now that would should produce an AWESOME shine and give you some serious protection. Bad intel. Super Sealant needs to be applied to clean paint in order to bond. If you re-apply the sealant, strip with IPA or strip wash (using dawn or all purpose cleaner). Link to comment Share on other sites More sharing options...
chas Posted January 12, 2012 Share Posted January 12, 2012 Good call, my bad, still too much of a noob to the Adam's products. Link to comment Share on other sites More sharing options...
babaron Posted January 12, 2012 Author Share Posted January 12, 2012 thx. washing is out of question since this is my 1969 camaro and it hasn't seen water for decades. I'll do an IPA wipedown then reseal then WAIT...then, wax. btw, this started when i took off the rear spoiler and saw the ugly crud and discoloration that accumulated after 14 yrs underneath. wish i had taken a picture of it. had to clean and polish it back to life and now its as glass smooth as the rest of the decklid. Link to comment Share on other sites More sharing options...
Z71_Denali Posted January 12, 2012 Share Posted January 12, 2012 honestly, i wouldn't worry too much about it! if you see any residual sealant hazing up within the 24 hours that you applied the MSS, then do an IPA wipedown. if not, RDWHAHB!!! Link to comment Share on other sites More sharing options...
THE Mook Posted January 12, 2012 Share Posted January 12, 2012 MSS needs to be applied to Bare paint in order to bond properly with the surface. Whether it's clean or not is your call. Do you see any uneven hazing in the paint now? With both on there I mean? Link to comment Share on other sites More sharing options...
Chris@Adams Posted January 12, 2012 Share Posted January 12, 2012 In my foolish haste, I inadvertantly put buttery wax over the machine super sealant without allowing it to cure. What should I do to correct this? Reclay and start over or what? I think that I would just wipe the Buttery off and leave it alone for a few days and re wipe if needed! Link to comment Share on other sites More sharing options...
Doug123 Posted January 12, 2012 Share Posted January 12, 2012 I am of the 'wait and see' school. If you have the buttery on over the MSS now, just wait and see if the finish looks a little hazy. If it is, strip it off with IPA solution and reapply the MSS. If not, you got away with it! Link to comment Share on other sites More sharing options...
chas Posted January 12, 2012 Share Posted January 12, 2012 I'm actually kind of glad I was wrong earlier I didn't know all this about MSS. I was totally under the impression that MSS could layer on top of something else. What would happen if you wanted to apply MSS on top of itself as a second coat or just to make sure you are covering areas evenly? Would you be doing more harm with that second layer than good? Link to comment Share on other sites More sharing options...
Doug123 Posted January 12, 2012 Share Posted January 12, 2012 I think Chewy does 2 coats of MSS and it works well for him. I would consider doing two coats of MSS if I could get 2 completely empty days off together (and cooperating weather and life!). Link to comment Share on other sites More sharing options...
babaron
10 answers to this question
