bigaudiofanatic Posted December 19, 2011 Share Posted December 19, 2011 Last weekend I got a chance to try a friends foam gun. I must say i am hooked!! I had to get one. Just in time for a winter. Link to comment Share on other sites More sharing options...
Bunky Posted January 1, 2012 Share Posted January 1, 2012 duplicate Link to comment Share on other sites More sharing options...
Chuckkilo3 Posted December 29, 2011 Share Posted December 29, 2011 I just got this one today. Will probably use it over the weekend. Amazon.com: Autogeek Half Gallon Foam Gun with FREE BONUS: Automotive Link to comment Share on other sites More sharing options...
Tim Posted December 30, 2011 Share Posted December 30, 2011 I ordered one of these from Eric, so now he might have 3 left??!!!! I can't wait to try it out. . . in the spring. . . when the water isn't frozen! I just ordered one too! Two to go? Link to comment Share on other sites More sharing options...
liquidred Posted December 31, 2011 Share Posted December 31, 2011 Stupid question but, what are the benefits of a foam gun? Do you still have to wipe it down with a wash pad to get the dirt off? I also am on the fence of buying one any tips would be beneficial sorry for the rookie question. Link to comment Share on other sites More sharing options...
irunnoft Posted December 31, 2011 Share Posted December 31, 2011 Stupid question but, what are the benefits of a foam gun? Do you still have to wipe it down with a wash pad to get the dirt off? I also am on the fence of buying one any tips would be beneficial sorry for the rookie question. One thing for sure, you never have to feel sorry for a rookie question on this forum! :group hug: As I understand it, the foam gun provides a good layer of foam on your car. You will want to rinse the car off first before you hit it with the foam gun. The pre-rinse is to knock off any large particles. Once the foam is laid down, it's purpose is to provide as safe a method as possible for washing your car using the two-bucket system. The foam doesn't actually break down the dirt or dissolve it. The agitation of the mitt across the surface of your car will be the key in removing the dirt. The foam acts as a barrier between dirt and your paint. Link to comment Share on other sites More sharing options...
irunnoft Posted December 31, 2011 Share Posted December 31, 2011 Now for my rookie question - I just got my Adam's Foam Gun from Eric and the directions are very sparse to say the least. I've got the canister, the screw lid, the gun, a small piece of vinyl tubing and then a plastic bag with several different colored inserts (?). I'm not sure what to do with the multi-colored pieces? What are they for? Where do I place them? As it is right now, I have the gun set up without any colored plastic pieces anywhere. So, anybody who has an Adam's Foam Gun, I'd appreciate your input on how to set it up. FWIW, I have low water pressure at my house, so I'm not sure if those pieces have anything do with the pressure. Thx Link to comment Share on other sites More sharing options...
egott_91 Posted December 31, 2011 Share Posted December 31, 2011 Now for my rookie question - I just got my Adam's Foam Gun from Eric and the directions are very sparse to say the least. I've got the canister, the screw lid, the gun, a small piece of vinyl tubing and then a plastic bag with several different colored inserts (?). I'm not sure what to do with the multi-colored pieces? What are they for? Where do I place them? As it is right now, I have the gun set up without any colored plastic pieces anywhere. So, anybody who has an Adam's Foam Gun, I'd appreciate your input on how to set it up. FWIW, I have low water pressure at my house, so I'm not sure if those pieces have anything do with the pressure. Thx The inserts are for the ratio of shampoo to water. Link to comment Share on other sites More sharing options...
irunnoft Posted January 1, 2012 Share Posted January 1, 2012 The inserts are for the ratio of shampoo to water. Can you give me a little more information? Which one do you use and why? Thx Link to comment Share on other sites More sharing options...
egott_91 Posted January 1, 2012 Share Posted January 1, 2012 Can you give me a little more information? Which one do you use and why? Thx I haven't put mine to use yet. I don't have any tip in there. Link to comment Share on other sites More sharing options...
irunnoft Posted January 1, 2012 Share Posted January 1, 2012 I used mine today without any tip and it seemed to do a great job. Link to comment Share on other sites More sharing options...
Bunky Posted January 1, 2012 Share Posted January 1, 2012 I have a foam gun similar to the Adam's. It came with 3 colored inserts (blue, green, yellow) that adjust the pull from the bottle. I found out the following with some searching. No insert in pickup- 12:1 42:1 (larger internal diameter) Blue 64:1 (recommended as the standard one) 128:1 (smallest inside diameter) I do not have them handy so I do not know if green or yellow has the most flow. Link to comment Share on other sites More sharing options...
THE Mook Posted December 29, 2011 Share Posted December 29, 2011 Gilmour is all I've used, and I must admit, I'm very UNDERwhelmed with it. It puts out a decent amount of foam, but it doesn't 'stick' to the car well like you see with the pressure washer versions. I've tried different soap levels, water levels, output settings, and they all seem roughly the same....poor (BTW, I'm using the "D" setting with 2oz Adam's Car Shampoo and I slowly fill the rest with water). It's nice that I don't have to pull out my pressure washer everytime though, but if it doesn't get the job done, then the point is moot. I have a Husky electric pressure washer, and after examining the nozzle heads, it's not very modular, i.e. no threaded attachment points, just 1/4 turn plastic ones. I may need a whole new handle to even be able to use a foam attachment. Anyone else experienced this? Have you tried filling the chamber with water, then say, adding 3 oz of Car Shampoo in it...putting the lid on it, and sloshing it around? I know for a fact the G brand gun can work pretty okay. Not like the Hydrofoamer, but you should still be able to get better sudsing... Mook Link to comment Share on other sites More sharing options...
eric@thompsonracing.us Posted January 2, 2012 Share Posted January 2, 2012 The metering tips are used to control flow. I personally run my gun without a tip, wide open. If you have low pressure, you're def gonna want to run it wide open. I have yet to find a reason I would want to meter flow. I start by filling the canister with water up to the neck. Then I add 2-4oz of Adam's Car Shampoo, screw the top on, then gently swirl. Link to comment Share on other sites More sharing options...
GeorgeDean Posted January 2, 2012 Share Posted January 2, 2012 I just ordered one from Thompsonracing Link to comment Share on other sites More sharing options...
irunnoft Posted January 2, 2012 Share Posted January 2, 2012 Eric, that's basically the formula I used and even with lower water pressure, it did a great job of shooting foam all over the car. If I had it to do all over again, I'd order it from you again. It's definitely worth the money AND it's one of the Adam's MADE IN USA foam guns so that's definite bonus! Now, if we could just get through winter and move straight on into summer where it stays light here until like 9:00pm! Link to comment Share on other sites More sharing options...
Hopper Posted January 11, 2012 Share Posted January 11, 2012 Do you guys leave the soap/water in the container between washes, or do you use it all/dump it out each time? Link to comment Share on other sites More sharing options...
chrys7 Posted January 11, 2012 Share Posted January 11, 2012 I have gotten to the point that I put just enough for a 1 car wash. So i end up using it all, if the wife washes same time i do then I double up on soap and water and her SUV takes a bit more soap to cover it all. But I never leave any soap in the foam gun cannister. I wash and rinse it after every use and put it away, thats just me. Link to comment Share on other sites More sharing options...
THE Mook Posted January 11, 2012 Share Posted January 11, 2012 The chamber and water/soap mixture I have provided is for one vehicle. You should ideally have ALL of the chamber released onto the vehicle. Then, don't forget to clean your foam gun. Link to comment Share on other sites More sharing options...
mc2hill Posted January 11, 2012 Share Posted January 11, 2012 I don't, like the others I mix enough for one vehicle. Dylan has stated that he leaves the water/soap mixture in his gun. Link to comment Share on other sites More sharing options...
blazr Posted February 3, 2012 Share Posted February 3, 2012 The pressure washer foamers are great, but like mentioned, requires a Pressure Washer! I have a couple of the Adam's Foam Guns still in stock. They are Made In USA. I also have a Gilmour II and it is not even close to the Adam's Gun in foam output. I have my Adam's Gun at my house and the Gilour at our shop. I'm dissapointed everytime I was a vehicle at the shop and have to use the Gilmour! Would you happen to have any Adam's Foam Guns left Eric? Link to comment Share on other sites More sharing options...
Golf for Life Posted February 3, 2012 Share Posted February 3, 2012 I always empty my foam gun reservoir after washing my cars. I use a gallon container to mix the soap and water mixture. If I have any shampoo and water mix left I just pour it back and save it for the next use. Link to comment Share on other sites More sharing options...
eric@thompsonracing.us Posted February 4, 2012 Share Posted February 4, 2012 I am currently out of stock, but working on a replacement. I'll put em up on our site if I find an alternative. Link to comment Share on other sites More sharing options...
DP 08 GXP Posted February 4, 2012 Share Posted February 4, 2012 i had the foam gun but was looking for something that would make the foam stick a little better....well i tried to get a foam cannon but the attachements wouldnt work with my pressure washer so i ended up getting a tornador foam gun to hook up to my air compressor...i havent gotten to use it yet but this spring i will be busting it out Link to comment Share on other sites More sharing options...
Z71_Denali Posted December 19, 2011 Share Posted December 19, 2011 i was looking on MTM Hydro's website, and i think they are Made in the USA... does your foamer have that stamped on it somewhere? Link to comment Share on other sites More sharing options...
chrys7 Posted December 19, 2011 Share Posted December 19, 2011 Which did you get i thought the Adams Gun was cut? Last weekend I got a chance to try a friends foam gun. I must say i am hooked!! I had to get one. Just in time for a winter. Link to comment Share on other sites More sharing options...
bigaudiofanatic
45 answers to this question
