ssbusdrvr Posted December 12, 2011 Share Posted December 12, 2011 Going to be doing paint correction then Sealant,Glaze,Americana.Since the Americana Special came with the Spray Sealant can you use it mixed with the Machine sealant( like in hard to reach spots so to ensure thorough coverage)Thanks:) Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted December 12, 2011 Share Posted December 12, 2011 I don't see why not. They both do the same thing, but then again I haven't used it yet. Im sure Dylan will chime in soon enough Link to comment Share on other sites More sharing options...
Z71_Denali Posted December 12, 2011 Share Posted December 12, 2011 apply the MSS, after you buff it off allow it to cure 12 to 24 hours. then if you want, apply a coat of QS, and after you buff it off allow it to cure 30 minutes before applying BG then APW Link to comment Share on other sites More sharing options...
Team Adam's Posted December 12, 2011 Share Posted December 12, 2011 If I'm understanding your question right your plan is to do the bulk of the car with MSS then go back and do tight spots and areas you can't reach with Quick Sealant? Thats fine... no problems there at all... just remember (as touched on above) to give the MSS its appropriate cure time. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted December 12, 2011 Share Posted December 12, 2011 If I'm understanding your question right your plan is to do the bulk of the car with MSS then go back and do tight spots and areas you can't reach with Quick Sealant? Thats fine... no problems there at all... just remember (as touched on above) to give the MSS its appropriate cure time. Just to see if i understood this correctly.....If The bulk of the car/truck is done with MSS, we should wait 12-24 before hitting the hard to reach areas with the Spray sealant? Link to comment Share on other sites More sharing options...
ssbusdrvr Posted December 12, 2011 Author Share Posted December 12, 2011 Thanks exactly going to have the PC out anyway so was planning on using Machine the spray on tight areas like the painted grill and wheels and thanks for reminding me about the cure times. Next issue is having patience to wait until after Christmas because Mrs Claus will have some of the goods. LOL Link to comment Share on other sites More sharing options...
Team Adam's Posted December 12, 2011 Share Posted December 12, 2011 Just to see if i understood this correctly.....If The bulk of the car/truck is done with MSS, we should wait 12-24 before hitting the hard to reach areas with the Spray sealant? No... apply MSS anywhere you can, then apply AQS where the MSS wasn't applied, don't apply anything over the MSS until its cured. Link to comment Share on other sites More sharing options...
ssbusdrvr
6 answers to this question
