I've seen some threads and even the Junkman mention in one of his videos that if you want to remove the handle you need to replace it with a bolt so the plastic cover doesn't slip off. However, I haven't seen anyone specify the correct size. So I'm gonna save you all a lot of time and give you the answer !
It's in metric. The correct bolt is: 8m 1.25 x 25mm. Fits perfectly with no excess hanging out.
Sandalwood
10 answers to this question
