Perez Posted September 2, 2011 Share Posted September 2, 2011 the way i dry my pads and it only takes a few hours to completely dry. It is a cheap box fan propped up on my push-up bars. sorry the metal around the fan is a little rusty.. Link to comment Share on other sites More sharing options...
Perez Posted September 3, 2011 Author Share Posted September 3, 2011 I do the EXACT same thing with the EXACT same fan. Pads are usually dry by the next morning. Just make sure that whatever you put on the grate isn't heavy enough to touch the spinning hub. just put what ever is holding the fan up off the ground towards the edges where its stronger and wont bend into the fan itself. Link to comment Share on other sites More sharing options...
MxRacer476 Posted September 5, 2011 Share Posted September 5, 2011 GREAT IDEA! Thanks!! Definitely will be using this tip! Link to comment Share on other sites More sharing options...
Photo Shooter Posted September 5, 2011 Share Posted September 5, 2011 I've found that foam applicators dry much faster when you extract as much water as possible after rinsing them. I roll them up in a towel. Compress them as flat as possible as you roll them up. Roll and squeeze; roll and squeeze. The towel will be saturated and your applicator be totally dry by next morning. Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted September 4, 2011 Share Posted September 4, 2011 Great tip... Link to comment Share on other sites More sharing options...
CrawlinTBSS Posted September 4, 2011 Share Posted September 4, 2011 That's a major no-no. It ruins the backing on them. Hrmm didnt think about that. Ill check them when i get to my shop and see. i really only click on the PC for like 2 seconds cause that initial start up whips most of the water out, i dont let it stay on and spin. Link to comment Share on other sites More sharing options...
the1inblue Posted September 4, 2011 Share Posted September 4, 2011 That's a major no-no. It ruins the backing on them. I don't think this will ruin them as long as you don't do it for long periods of time. Junkman spins them out when showed how to use the universal pad washer. Sent from my DROIDX using Tapatalk Link to comment Share on other sites More sharing options...
Team Adam's Posted September 4, 2011 Share Posted September 4, 2011 then spin em on the PC fast That's a major no-no. It ruins the backing on them. Link to comment Share on other sites More sharing options...
Vincenzo Posted September 3, 2011 Share Posted September 3, 2011 I have a round fan with a flat face that swivels and rotates...... I prop 3 books underneath it and aim it straight up, put it on low and let the pads dry out. Usually does it overnight. Link to comment Share on other sites More sharing options...
CrawlinTBSS Posted September 3, 2011 Share Posted September 3, 2011 not a bad idea. i wring mine out good then spin em on the PC fast and let em air dry. usually dry after 6hours or so, especially if they dry outside in the heat. Link to comment Share on other sites More sharing options...
Chris@Adams Posted September 3, 2011 Share Posted September 3, 2011 Thats one way! Link to comment Share on other sites More sharing options...
Perez Posted September 3, 2011 Author Share Posted September 3, 2011 i usually ring them out pretty good then put them on there on medium and there dry in 2 hours. edit** the newer pads without the plastic ring are a bit lighter and when they are dry they become to light and the air lifts them off. easy to know when there dry Link to comment Share on other sites More sharing options...
XQIZT Posted September 3, 2011 Share Posted September 3, 2011 I do the EXACT same thing with the EXACT same fan. Pads are usually dry by the next morning. Just make sure that whatever you put on the grate isn't heavy enough to touch the spinning hub. Link to comment Share on other sites More sharing options...
Bill-V8V Posted September 3, 2011 Share Posted September 3, 2011 Great tip Ray, thanks for sharing :thumbsup: Link to comment Share on other sites More sharing options...
sluggoZ Posted September 3, 2011 Share Posted September 3, 2011 Great idea! Link to comment Share on other sites More sharing options...
Team Adam's Posted September 3, 2011 Share Posted September 3, 2011 Great idea! Link to comment Share on other sites More sharing options...
smokemeister25 Posted September 3, 2011 Share Posted September 3, 2011 that's a great tip. last week i put mine in the coldest bathroom in the basement bathroom. two days later they were still wet. junkman told me to put them out in the sun so i laid them on my grit guard and it still took quite a while for them to dry. so this is a good idea. thanks Link to comment Share on other sites More sharing options...
TK427 Posted September 2, 2011 Share Posted September 2, 2011 That’s what I'm talking about!!! This is the very reason I keep checking the new post as often as I can. Great tip Link to comment Share on other sites More sharing options...
ChargerMatt Posted September 2, 2011 Share Posted September 2, 2011 Simple, cheap, effective. A+. Link to comment Share on other sites More sharing options...
Perez
18 answers to this question
