Diggerdan11 Posted July 13, 2011 Share Posted July 13, 2011 so when i detailed my truck this weekend i used SSR for the first time. On my previous details i did not feel the need to go as agressive as SSR. Well I noticed that as soon as i started using the SSR little bits of green dust went all over the place. Is this normal for the SSR? I tried to use as little of product as possible and i did not have the same problem with the SHR or FMP Link to comment Share on other sites More sharing options...
Chewy Posted July 13, 2011 Share Posted July 13, 2011 I notice more dust with the SSR as well. A bit of DS will help control it some, but it's somewhat par for the course. Chris Link to comment Share on other sites More sharing options...
Redvenm Posted July 13, 2011 Share Posted July 13, 2011 I notice more dust with the SSR as well. A bit of DS will help control it some, but it's somewhat par for the course. Chris Same here with the SSR. Keep DS on there and you should be fine. Link to comment Share on other sites More sharing options...
Team Adam's Posted July 13, 2011 Share Posted July 13, 2011 Some dusting with SSR is normal, part of the price you pay for using a large abrasive and no silicones to fill, plus the addition of the open celled foam pads allows for much more air flow. Make sure you're not over doing the product and priming often. Link to comment Share on other sites More sharing options...
Diggerdan11 Posted July 13, 2011 Author Share Posted July 13, 2011 Ok thanks guys, glad to know that its kinda normal to have dusting with the SSR. Next time i will try to keep the pad a little more wet with DS Link to comment Share on other sites More sharing options...
green6767 Posted July 13, 2011 Share Posted July 13, 2011 I've also noticed the dusting and as the others have mentioned, the DS works wonders. I also found it effective to knock the PC down to the lowest settings after you first dap the SSR over your area AND after each re-prime of DS and quickly spread it all around. Then back up to your 5 or 6 settings and back to work with the passes as normal. Link to comment Share on other sites More sharing options...
Perez Posted July 13, 2011 Share Posted July 13, 2011 prime more and less product.. also make sure your not working in direct sun and the surface is hot. Link to comment Share on other sites More sharing options...
Chris@Adams Posted July 13, 2011 Share Posted July 13, 2011 I notice more dust with the SSR as well. A bit of DS will help control it some, but it's somewhat par for the course. Chris Link to comment Share on other sites More sharing options...
1121ken Posted July 14, 2011 Share Posted July 14, 2011 i agree i used it for the first time and was like ok is this much supposed to be coming off.. and i got told the same thing i am in italy and its hot all the time over here right now so i have to spray a extra spritz or two every time to keep it down plus with the heat... good luck Link to comment Share on other sites More sharing options...
Diggerdan11
8 answers to this question
