crime2 Posted June 28, 2011 Share Posted June 28, 2011 How long do you guys let BG haze over for? I have been doing a on / off. Should I be letting it sit for 5 mins or so? Link to comment Share on other sites More sharing options...
Redvenm Posted June 28, 2011 Share Posted June 28, 2011 Until it is completely hazed over, depending on how hot or humid it is it can take 5 minutes or as much as 30 minutes. If you put it on too heavy it can take longer too. I go all the way around the car and then check back where I started to see if it is completely dry where I started, if it is I start removing it. If it isn't I walk away and check back. Exactly how I use it. Link to comment Share on other sites More sharing options...
Bill-V8V Posted June 28, 2011 Share Posted June 28, 2011 How long do you guys let BG haze over for? I have been doing a on / off. Should I be letting it sit for 5 mins or so? Until it is completely hazed over, depending on how hot or humid it is it can take 5 minutes or as much as 30 minutes. If you put it on too heavy it can take longer too. I go all the way around the car and then check back where I started to see if it is completely dry where I started, if it is I start removing it. If it isn't I walk away and check back. Link to comment Share on other sites More sharing options...
FP Posted June 28, 2011 Share Posted June 28, 2011 I usually apply it wherever I'm applying it, and remove it when done. Usually about 5 - 7 minutes. Link to comment Share on other sites More sharing options...
crime2
28 answers to this question
