TX GMC Posted May 4, 2011 Share Posted May 4, 2011 How do you do it again? I can't find my DVD and can't find the topic on it. Washing PC pads Mistyped from my iPhone using Tapatalk <object width="1280" height="750"><param name="movie" value="http://www.youtube.com/watch?v=0PQabUpVZes?fs=1&hl=en_US&hd=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=0PQabUpVZes?fs=1&hl=en_US&hd=1" type="application/x-shockwave-flash" width="1280" height="750" allowscriptaccess="always" allowfullscreen="true"></embed></object> Link to comment Share on other sites More sharing options...
Chobbs Posted May 4, 2011 Share Posted May 4, 2011 Here's a tip from a founding member of this forum (C6Bill?) once you have finished washing the pads. Put them back on the PC and give the on/off switch a quick "on" then "off". It will spin a lot of water out of the pad allowing it to dry quicker! Do not let it spin too much as you run the risk of the pad flying of the polisher. Just a few quick bursts. Link to comment Share on other sites More sharing options...
Osok Posted May 4, 2011 Share Posted May 4, 2011 Pad washer!!! Got one at Christmas last year and got to use it a few times this spring already. It's ooooh so nice. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 once my basement is fixed and my area is set up in the laundry room, I want to try this with my dehumidifier Link to comment Share on other sites More sharing options...
1anonly Posted May 4, 2011 Share Posted May 4, 2011 I seen the tip in the pad washing Junkman video. I modified a little. I do what Chewy does with the spot pad backing plate, but I also took a silver Sharpie and made a circle on the backing of my pads. The circle tells me where the center of the pad is. It is important to center it when using a drill to spin dry. Then I place them face down on a drying rack next to a dehumidifyer. My pads are dry within 12 hours. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 Well if you heard it from me then there's only a 50% chance it's right come on Bill.. tell the truth.. 33%? Link to comment Share on other sites More sharing options...
Chewy Posted May 4, 2011 Share Posted May 4, 2011 I actually stick it on my drill using my focus backing pad to attach it to it. Do a quick spin and then let air dry. Chris Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 4, 2011 Share Posted May 4, 2011 Well your the one I heard it from so I couldn't take credit either Well if you heard it from me then there's only a 50% chance it's right Link to comment Share on other sites More sharing options...
Chobbs Posted May 4, 2011 Share Posted May 4, 2011 Well your the one I heard it from so I couldn't take credit either Link to comment Share on other sites More sharing options...
Bill-V8V Posted May 4, 2011 Share Posted May 4, 2011 Here's a tip from a founding member of this forum (C6Bill?) once you have finished washing the pads. Put them back on the PC and give the on/off switch a quick "on" then "off". It will spin a lot of water out of the pad allowing it to dry quicker! Do not let it spin too much as you run the risk of the pad flying of the polisher. Just a few quick bursts. That is a great tip, I wish I could take credit for it but it wasn't me who started it. I just pass it along Link to comment Share on other sites More sharing options...
mc2hill Posted May 4, 2011 Share Posted May 4, 2011 Here's a tip from a founding member of this forum (C6Bill?) once you have finished washing the pads. Put them back on the PC and give the on/off switch a quick "on" then "off". It will spin a lot of water out of the pad allowing it to dry quicker! Do not let it spin too much as you run the risk of the pad flying of the polisher. Just a few quick bursts. What Craig said^. Do this inside a bucket - keeps the water from flying everywhere and if the pad did fall off the backing plate it doesn't get dirty. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 Also if you use the machine no fabric softner and no hot water you shouldnt put the pads in the actual washer.. Link to comment Share on other sites More sharing options...
MAYBEN Posted May 4, 2011 Share Posted May 4, 2011 I want a Pad Washer.. Link to comment Share on other sites More sharing options...
03Ap1 Posted May 4, 2011 Share Posted May 4, 2011 Also if you use the machine no fabric softner and no hot water Link to comment Share on other sites More sharing options...
Frid Posted May 4, 2011 Share Posted May 4, 2011 Pretty easy to clean them. Just make sure if you are cleaning them by hand that the water is clear when rinsing. Would be bad to get some polish to dry up in them. Link to comment Share on other sites More sharing options...
Chris@Adams Posted May 4, 2011 Share Posted May 4, 2011 I wash mine in my sink with APC & warm water. Squeeze out water put up to dry! Link to comment Share on other sites More sharing options...
BlueGenCoupe Posted May 4, 2011 Share Posted May 4, 2011 Or you can use a pad washer. Link to comment Share on other sites More sharing options...
Bigredmariner Posted May 4, 2011 Share Posted May 4, 2011 Here it is. Man I gotta learn how to embed here. Link to comment Share on other sites More sharing options...
RedexInLA Posted May 4, 2011 Share Posted May 4, 2011 I spray it with APC, work it with my fingers and rinse well, gently remove most of the water from the pad and then put it on a rack of some kind face down. I don't seal mine, I put them in my canvas bag. Link to comment Share on other sites More sharing options...
TX GMC
Washing PC pads
18 answers to this question
