gtfitter597 Posted April 19, 2011 Share Posted April 19, 2011 I have a 2010 Camaro with gloss orange stripes. Would there be any harm with using the swirl remover, polish, and buttery wax as I would w/ the rest of the car? THANKS!!!!!!! Link to comment Share on other sites More sharing options...
the1inblue Posted April 19, 2011 Share Posted April 19, 2011 I wouldn't use any of it myself. I got a bottle of the clear polish from Eric@thompson racing. It used for vinyl stripes and graphics. SHR could ruin them I would think and buttery wax would leave a white residue on the edges. Sent from my DROIDX using Tapatalk Link to comment Share on other sites More sharing options...
Team Adam's Posted April 19, 2011 Share Posted April 19, 2011 On the gloss stripes actually YES you can use waxes to protect them. I would advise you against using SHR as the stock vinyl is only top coated (not thru and thru) so if you remove too much material you'll actually show up white vinyl underneath. Just apply a thin coat of buttery wax to them to keep them protected... if you notice any spots or defects use Fine Machine Polish or Revive Polish by hand to polish them out. Link to comment Share on other sites More sharing options...
gtfitter597 Posted April 19, 2011 Author Share Posted April 19, 2011 This is the grey area I run into after reading others posts, do I tape them off? Obviously you would want to get as close to them as possible. Would just like a definate answer from someone who has vinyl stripes. Link to comment Share on other sites More sharing options...
Team Adam's Posted April 19, 2011 Share Posted April 19, 2011 Tape them off, or don't cross the edges. You're not going to damage them if you do, but you will end up with product caked up agains the edge which will look unsightly. Simply mask the stripes while you're working on the paint, then mask the paint when you're working on the stripes. Link to comment Share on other sites More sharing options...
Bill-V8V Posted April 19, 2011 Share Posted April 19, 2011 This is the grey area I run into after reading others posts, do I tape them off? Obviously you would want to get as close to them as possible. Would just like a definate answer from someone who has vinyl stripes. You can tape them off to keep from getting a white border around them, similar to a clear bra, but beyond that follow Dylan's advice and you'll be fine Link to comment Share on other sites More sharing options...
gtfitter597 Posted April 19, 2011 Author Share Posted April 19, 2011 **** I knew I shoulda just gotten a white car and had them painted. Its going to suck becuase there's that small outlining vinyl that's about 1/4" wide around the large stripes w/ 1/4" paint in between. Well thanks for the fast responses, just spent too much money on products but it should be worth it! Link to comment Share on other sites More sharing options...
Team Adam's Posted April 19, 2011 Share Posted April 19, 2011 Yea, vinyl stripes are a pain... having them shot and cleared makes life so much easier! Link to comment Share on other sites More sharing options...
Chris@Adams Posted April 19, 2011 Share Posted April 19, 2011 Post up some pics of your Camaro! Link to comment Share on other sites More sharing options...
crewxp Posted April 19, 2011 Share Posted April 19, 2011 I havent actually had time to wax and polish yet, but I plan on it sometime within a week after a previous thread I made earlier today. I have stripes as well and a Camaro. From what I've read, use blue tape to cover the edges of the stripes. I've actually tested the SHR by hand and let me say, watch the edges! Looks really bad when a bright color gets stuck under the stripe or inside the car cracks! Annoying to get out too. I actually have black matte stripes on mine. I put detail spray first on them but always got streaks on it. I'm going back and forth between brilliant glaze and in and out spray on them. To me I like in and out better, definitely makes it pop without making it too glossy and taking away from the matte finish. Curious as to if there's a non spray solution as in and out runs out fast Link to comment Share on other sites More sharing options...
Bill-V8V Posted April 19, 2011 Share Posted April 19, 2011 Curious as to if there's a non spray solution as in and out runs out fast VRT Link to comment Share on other sites More sharing options...
dipolley Posted April 19, 2011 Share Posted April 19, 2011 VRT Dilute the VRT 50/50 with water in a spray bottle. It won't be AS shiney as straight VRT. Add more water or VRT to get the level of shineyness you want. Link to comment Share on other sites More sharing options...
jmelchio Posted April 19, 2011 Share Posted April 19, 2011 Good thread. I have a silver camaro with black vinyl stripes (flat black), so I'm going to have the same issue. Link to comment Share on other sites More sharing options...
Chobbs Posted April 19, 2011 Share Posted April 19, 2011 I've been putting brilliant glaze on my camaro stripes(glossy). They look great. I'd be scared to try and remove any swirls...if I had em in the stripe. Link to comment Share on other sites More sharing options...
gtfitter597
THANKS!!!!!!!
13 answers to this question
